Karl":yq4pbxmi said:You turned real neanderthal and honed it freehand![]()
Of all the possibilities the simplest was never going to be an option as it had to involve a jig to be sure that it was exactly the 'right' angle :wink:
Steve, no, the angle I chose is purely arbitrary...35deg seemed a reasonable angle being 10 less that the honed edge. The main thing is that once I'd figured that the planer grinding jig would sort of do the job it really only took around 10 mins to get that bevel. I actually did think about doing it freehand but bottled out... I'm going to get the latest version of the Tormek plane and chisel jig at the AxBash next month so that I won't have to use the planer blade jig again - Robpromhandicam":3olmi15w said:Karl":3olmi15w said:You turned real neanderthal and honed it freehand![]()
Dunno, but this is what the actual jig looks like, I dispensed with the top bar that clamps the blade - RobAndyT":3q051zae said:I don't get it.
Why are the two outer holes there?
Is it a half-implemented feature for wide blades (just add extra brass plate)?
A manufacturing mistake?
David, I don't think the combined efforts of Napoleon's Grand Army and the Roman legions would have any success in persuading you to part from an Eclipse gauge :lol: :lol: The idea here was simply to relieve the 45deg bevel (which is too wide to keep on honing) by removing most of it and replacing it with a 35deg ground bevel, in much the same way that you would do with a normal plane iron. This means that it's now easy to to hone the edge at 45deg, polish the back (ruler trick) and then turn the hook. I've also found that if the sharp corners are relieved, or rounded slightly, there's no 'dig in' so no need to camber the blade. I tried it yesterday on a test piece of oak and it now works very well...which it didn't straight out the box - RobDavid C":3m6rlk6l said:Well, I still prefer the Eclipse type option.
The small roller makes cambering and setting of the blade, much easier.
The 35 degree grinding is an excellent idea. The sharp 45 degree edge with a hook seems infinitely preferable to the 60 degree perversion suggested in the original literature.
The first is a cutting edge producing a type two shaving. The second is a type three scraping shaving. It is only recommended because it is easier to set up than the hook, where there are many parameters to go wrong. I cover this in detail in my 6th DVD.
best wishes,
David Charlesworth
