Sharpening Veritas vs. other router planes
Silly_Billy
21 Jan 2018
Southern England
Please could anyone advise me if Vertitas' router plane is the only one that can be sharpened in the conventional way?
I know Veritas has the two piece system, so that the blade can be separated and attached to an aluminum holder for sharpening. Do any other router planes have anything similar (but cheaper than Veritas)?
What do you mean by the conventional way?
I can’t speak to the Veritas specifically but I can say that sharpening a 071 router plane iron is much the same as sharpening anything else, albeit a bit more awkward. Are all of Veritas’ router irons two piece? I believe that other router plane irons are one single unit (the stem and head are one piece) - my Record 071 irons are one piece at least. Although I have an old pointed iron that is two piece...
I assume conventional in that you can take the blade off and sharpen like a standard plane blade...
I know Veritas has the two piece system, so that the blade can be separated and attached to an aluminum holder for sharpening. Do any other router planes have anything similar?
I posted a link to a video by Viv Tesolin in another thread. Here is it again:
http://www.finewoodworking.com/2017/12/15/sharpening-router-plane-vic-tesolin
There is a detailed description of the process on my website:
http://www.inthewoodshop.com/WoodworkTe ... lades.html
Regards from Perth
Derek
Only the larger ones, where there's room for a screw in the "heel" of the iron. The narrower ones are one-piece just like everybody else's.
I believe that was the standard with 071s; mine also came with a one-piece "standard" blade and a two-piece pointed one. I can only guess that the pointed one was easier to manufacture in two pieces. If it had anything to do with sharpening, why not make them all in two pieces?
Incidentally, I managed to snap my two-piece blade across the screwhole when I drove it into a knot.
