gidon
I couldn't resist an Digital Blue QX5 microscope on Ebay for comparing sharpening methods. It works to around 200x magnification. It's a toy really but gives passable results - although you need to employ additional lighting for the 200x magnification. I have tried this before but with a more sophisticated setup which actually gave better results but was a lot more fiddly to use.
Here's a few pics (all 200x mag) I've done with it which may be of interest to some of you. I have a vast plethora of sharpening gear so happy to try anything anyone is interested to see the results of time permitting.
BIC disposable razor (note the three microbevels)
Complete sharpening done on Tormek
Spyderco Ultra Fine (grind Tormek, secondary bevel 1200 grit DMT, microbevel Spyderco UF)
DMT 8000 grit (D8EE) (grind Tormek, secondary bevel 1200 grit DMT, microbevel D8EE)
600 grit DMT stone secondary bevel, polished with Tormek compound on MDF (grind on coarse graded Tormek stone)
Waterstones, 1000 grit raise burr, 4000 1st microbevel and chase bur, 6000 secondary micro bevel
Final microbevel polished on 1 micron diamond paste on maple
Microfinishing film 0.5 micron (tormek coarse, secondary 600 grit DMT, 1st mb 5 micron film, 2nd mb 0.5 micron film)
Some comments / conclusions
All the methods pictured above provide a very sharp edge - all will shave, cleanly pare end grain and cut paper by push alone. How long that edge lasts in another matter all together. For me diamond stones produce the edge quickest with minimum fuss.
The 8000 grit DMT stone is a bit of an anomaly - it's not a polishing stone as it grit would suggest - for removing all traces of the burr and an ultimate edge you still need to go to a leather strop or some honing compound on MDF (or a Spyderco UF just about). But it does cut very quickly and if you sharpen frequently - you could do so on this stone alone.
The Spyderco UF is a polishing stone only - it cuts very slowly compared to the DMT 8000 or my 6000 grit Waterstone. Its grit for comparison is hard to judge - Spyderco won't state what it equates to in Waterstone terms - the only site that puts a value on it is the Axminster site - which states 10000 grit - which I would say seems fair. My stone although flat (the UFs are surface ground so should be flat unlike the other Spydercos) needed a lot of work to remove the surface grinding marks left by Spyderco's flattening process. I hate to say it because it's a lot of money but the 8000 grit DMT and the Spyderco work nicely together in my opinion - if you want to completely avoid messing around with strops and honing compounds.
Waterstones if you don't mind the mess and flattening give a very nice even scratch pattern. And they too cut quickly.
If I had to get rid of evertything except one stone, I'd probably keep the red DMT stone (600 grit). It's fast, and leaves a pretty even scratch pattern. I'd then finish off with Autosol, Tormek honing compound, Veritas green honing compound or Clifton Blue honing compound on some MDF.
Note for more on this stuff have a look here.
Welcome any comments / discussion.
Gidon
Gidon
