Chris_belgium
- Joined
- 7 May 2006
- Messages
- 272
- Reaction score
- 0
Hello, I'm trying to hone my sharpening skills, I have purchased some waterstones + accesories, and I do manage to get a decent result, but I have the feeling that I'm doing something wrong. I have purchased the David Charlesworht books + have spent hours searching this forum, but have yet to find a simple step by step howto. Wich is really what a novice like me needs. So if anyone has the time and feels up for it, please give me a step by step
Stones I have, 220, 800, 1200, 6000 (+nagura) king brand waterstones + veritas MKII
'technique' I've been using:
Step 1: flattening the back of the blade first with 800 grit, then 1200 grit, then using the ruler trick, hone the back with 6000 grit
Step 2: (using the MKII at 30°) hone the pirmary bevel on the blade again with 800 and then 1200 grit
Step 3: adjusting the brass knob on the MKII to hone a secondary bevel on the 6000 stone
As I said, results are ok, but IMHO should be better. In the DC book he speaks about honing a wire edge with the 800 stone but then fails to explain what to do when achieving this wire edge or even what the reason for this wire edge is. (surely all my fault, since English is not my mother language, lost in translation and all that ) I can get a wire edge when I only sharpen with a pull stroke, but as soon as I start going back and forth, I am not getting a wire edge?
Another thing wich is unclear to me is, is the nagura stone only to be used on the 6000 grit or should it be used on the 1200/800 also?
Thanks for your time, christof.
