Sharpening system
Aled Dafis":1slvhktt said:
Olly, what abrasives do you use? I'm considering using the 3M sheets from Workshopheaven, but haven't yet found the time to try them.
Hi Aled,
Well, I did buy some dirt-cheap Silverline ones (red, aluminium oxide) from Amazon. They're fine for the old, thinner steel and most chisels (although they do seem to spark a bit more) but, with modern A2, O1 etc., I find they lose their edge too quickly. So, I'm still looking for the best solution for regrinding, say, a 25° primary bevel on a 2in wide plane iron. :(
CSM Abrasives sell silicon carbide discs in 80g though, I fear they might have a minimum order quantity of 25... You could could the Workshop Heaven sheets to size no problem. But still, they aren't coarse enough for heavy grinding.
I might also try contacting Norton UK to see whether they can supply (as they're the ones who make the supplied discs).
I use the Hermes self adhesive 150 mm discs from Axminster.
There are available in 7 grids from P40-180.
They are not superior but the are cheap and can easily be replaced.
OPJ":2r5dafon said:
Hi Aled,
Why do you need to regrind? You must stop dropping your chisels on concrete :wink:
Agree.
If you use my method you never need to regrind in the lifetime of a tool, except to rectify damage.
I have the veritas sharpening system which is like the worksharp one. I buy the abrasives in sheets from fibre optic polishing sites thaey come on a A4 sheet and you just cut to size. They are a bit cheaper than the other sites listed above and you can get very fine abrasives.
Just search 3m fibre optic polishing and there are some good sites.
Owen
