Sharpening my Shavehook
fergie86
New member
5 Mar 2010
Hi all,
I have recently started refurbishing the old doors in my house. I plan to strip all the paint and varnish down to the bare wood and then re-varnish them. So far I have been using my sharpened chisels to remove the bulk of it however for the mouldings I need to get my shavehooks sharp enough to remove the paint in the hard-to-reach areas. I have trawled the internet for a solution but so far to no avail!
any tips/ideas would be very much appreciated!
Also on another note I have hear that a quick rub down with a clean rag and vinegar on the bare wood helps bring out the grain, is this true or just a chip-shop style myth?
fergie86":2u6sir6p said:
Hi all,
I was under the impression that shavehooks are deliberately blunt, and are only intended for use on paint that has been softened, by heat or chemical.
BugBear
I have had reasonable results by filing the edges with a 'medium' cut file. Effectively run a new bevel with a cutting edge included angle of 70 - 80 degrees, or whatever suits your technique. I have not found a shavehook with decent steel so your not looking at chisel sharp. They work best with some form of stripper, be it chemical or heat.
HTH
xy
ah maybe that's where i'm going wrong! Any ideas of an alternative method for getting into the detailing of the mouldings?
I assume you are meaning the narrow grooves etc.? Now that is something I've been asking myself for a long time. I usually end up scratching with almost anything. A lot depends on whether you are using a stripper or not. But buggered screwdriver, nail, as I said almost anything. I suppose a wire brush would work on softened paint but there is a risk of damaging the surrounding surface.
xy
thanks for the reply!
i saw a video on youtube (trying desperately to find it again) which took the bulk of the paint off using a heat gun and UV lamp then used sharpened scrapers to shave off the top layer of wood to get a nice smooth finish.
I am with houtslager.
The heat may come from a gas flame or a heat gun or a special (and expensive) ultarviolet heater. A scraper is made to fit the profile in a rather roundabout way. The scraper is filed sharp and resharpened when needed.
Don't destroy nice mouldings with a router.
Hello Fergie
Paint stripper & toothbrush - clean with white spirit - no grain raising
A heat gun is less fierce than a blowtorch, be carefull not to scorch Leopard spots all over the door (haha)
I'm experimenting with sanding blocks from Polymorph heat mouldable plastic (Ebay)
Good luck
Matt
