I use everything I can find in stones (except for soft synthetic waterstones), freehand.[/quote
That's pretty much where I'm at. Probably the biggest difference is that so far I have managed to resist going down the jnat rabbit hole.
For rough shaping I use one of 5 or so bench grinders. Bevel shaping is often on a slow speed 8" machine with a cbn wheel. Heavy back flattening will get me to set up the Makita flat top with diamond disks. I have disks for that machine from 80 grit to 3000 grit
Most of the time I don't need those machines.
I have several drawers full of bench stones. Idk, maybe 50 or 60. Not all of them are fabulous rocks... I have a tendency to pick up anything interesting that I can get for cheap. Some of them are more "interesting" than useful. However, at this point I have several approaches to honing fairly well represented and can experiment around amongst them.
Just off of the top of my head:
Arkansas stones, soft to surgical black. These vary wildly in size and quality.
Diamond stones, maybe 100 grit to 1200 grit.
Waterstones, up to (iirc) 14000 grit I rarely use these.
Sandpaper on glass up to .3 micron lapping film, though nowhere near a full progression.
Norton India oilstones, coarse medium and fine.
Some random stuff like coticules, slate stones and barber's razor hones.
Also a spyderco ultrafine. And some jaspers. And some rocks I have picked up off of the ground and flattened. I once owned a 2 sided stone with one side sandstone and the other side slate. It was too slow for me at the time so I gave it away. I kind of regret that now as I've never seen another.
Also a drawer full of shaped abrasive sticks for things like carving tools. Those run the gamut of abrasive types.
What I use day to day on the bench to keep chisels and planes sharp? I do mix it up a bit just because I can but generally diamond for coarse work if needed followed by washita or hard ark for mid level honing and finish on the spyderco or surgical black. All of those get alcohol as the honing fluid.
If I need to hone on a jobsite I use an old well broken in 600g dmt plate and call it good.
