Sharpening for beginners
Peter907
21 Jun 2022
Mansfield
I've just bought a sharpening kit and some lapping fluid. The kit has a 400 grit diamond plate, a 1000 grit diamond plate and an 8000 grit ceramic plate. I've watched numerous YouTube videos about sharpening, and the principles explained seem perfectly straightforward, but after several hours of practice with 4 different sized chisels (30mm to 6mm) working both with and without a honing guide, I have yet to achieve the stage where I can sharpen a chisel or my penknife to a sharpness where I can shave hairs from my arm or cut a sheet of printer paper without it leaving a jagged torn edge. Any advice or thoughts would be helpful.
Make sure you get a burr or wire edge at each grit before moving on to the next. This burr "proves" that you have got all the way to the point.
If you move on to a higher grit while still having a blunt point it will take hours to get there.
Normally you will be spending the most time on the rougher stone to get the shape right then each finer grit is just polishing it more and more.
struggled with this myself in the past
got a veritas honing guide which is repeatable
also learnt that the back of the chisel is vital to work on as well
as the bevel
Main problem for beginner modern sharpeners is honing jigs and guides. They make it more difficult, mainly because you can't get full force on them so it all takes longer, but also they make the essential "little and often" less easy. Too much fiddling about is a deterrent.
They were fairly uncommon fifty years ago, just a gadget for amateurs.
I discovered this belatedly and since then haven't touched one in years.
Takes a minute or so to sharpen a chisel freehand.
Main thing is to do it fast and forcefully, bringing up a burr over the whole width of the edge - easy to miss on a plane blade which tends to get more wear in the middle which can get overlooked.
Second essential is to do it a little and often; you keep your edge sharp, don't put it off, touch it up frequently.
This is the best way IMHO.
I made wooden furniture professionally for 20 years or so. Working oak in particular, sharpening is an almost continuous process. Tried a few sharpening systems but always went back to the India Stone that I've had for 50 years, in a box I made with extensions for the stone so the whole stone gets used. I used to take back the grinding angle regularly on a high speed bench grinder. Open faced wheel, light touch, and plenty of cooling. I did use a jig for that. Two pieces of 1" X 1/4" drilled and tapped to make a clamp across the blade to give the required angle against the grinder rest. High tech!
I haven't lost a "patient" yet doing it that way, but you really don't want to discolour the steel at all.
I watched Paul Sellers video showing his method of sharpening on diamond plates by hand without a honing guide. It made a lot of sense to me and seemed such a quick and easy method. After re-watching his video a couple of times and practicing his method for an hour, my edges won't even draw blood from my fingers unless I try very hard. I can't understand what the 8000 grit ceramic plate even does. It looks and feels like perfectly smooth white plastic which just gets permanent grey markings from the steel. Surely with diamond alone, I should be getting reasonable results within a few minutes. Is sharpening normally so difficult to master? Despite the time, effort and expense, so far, I'm wondering if I should seek out a local company that I can pay to sharpen my stuff, which is very frustrating.
Do not dispair, there has to be a reason it is not working.
The 8000 grit is basically just polishing to a very shiny finish like a strop. The grey is the steel so it sounds like it is working ok.
The jumps between your grits are a bit big to be fair. I use Norton waterstones and the coarse one is 1000 then 4000 then 8000.
On my worksharp with abrasive paper I use more in between. This is not to say you can`t get a razor sharp edge with those grits.
I wonder if the problem is the chisels you are trying to sharpen, are they very cheap or poor quaility metal ? have they been ground too hot and lost their temper perhaps ? Only because it is much harder to sharpen soft steel.
The difference in steels is very noticable, I have one particular old slick that I found at a car boot sale that just has the best steel ever and it sharpens so well and stays sharp.
Pick a medium sized chisel and stick to that. maybe do a few photos one after each grit or something.
8000 is a very fine grit stone and a big step from the 1000 plate. You need a grit inbetween like 3000. You could just strop with stropping compound after the 1000 g plate like Mr Sellers does. Leave the 8000 stone for down the track a bit when you have come to grips with the basics. Like Jacob and Amplidyne I have gone back to a Norton India oilstone and strop with compound afterwords. Does not matter if its diamond plate or stones the same principals apply. You have to raise a burr at each step. Anyhow we all have to start someplace so I think this video shows how basic it can be.
Beginner how to sharpen a chisel - Google Search
Perhaps use the guide for a while to get started and move on to freehand when you feel ready.
Regards
