Sharpening conspiracy!
I see that knife sharpening madness is getting to you!
Why on earth would a so called "Scandi"edge produce a better result than any other "configuration" - given the same angle at the sharp end. It makes no sense at all. If there is any difference it can only be in the differing technique used to produce the angle, one perhaps being more effective than the other.
Why would a convex edge be stronger - for the same edge angle the convex edge takes away more metal and must be weaker?
Obviously poorly made or poorly designed knives are less good - by definition.
What about a well made and well designed knife with "poorer" steel? Wouldn't that just mean easier sharpening but faster blunting?
I can see the point of a laminated knife with hard centre and softer outer. This is common with older chisels and plane blades; hard face attached to soft back and slightly easier to sharpen.
Are you teasin' me now, you rascal? I cannot believe that you would be so unaware of these knife bevel profile matters as to dismiss them out of hand.
Even if you think logically about the shape of the knife bevels and how they would affect various kind of cutting attempts on various shapes of surface, you would surely grasp the reasons for these different grinds. Actually carve something and the differences become irrefutable.
But if you can't be bovvered ..... perhaps I'll write a post of not less than 1000 words to explain. :)
I might have a go at carving. I've got a Mora knife a hook knife and various gouges. I'd guess that a normal rounded bevel would be best, and it's easiest.
You'll discover that the rounded bevels will tend to force you to make cuts at too steep an angle to take very thin shavings from many surfaces. BTW, you'll also find it advantageous to have one knife longer than the other and one with a very sharp point and both a curved edge and a straight edge and hook knives of different curvatures and .......
On the other hand, you may be so skilful that you can make a fine and elegant thing with nowt but a blunt & rusty Swiss Army knife. I hope to see this item here soon, including the close-ups. :)
That reminds me - can you point us to some posts picturing some of your wooden productions?
Not for the same edge angle. The rounded bevel gives you more control, it's rounded under the edge angle and effectively finer than a flat bevel edge with the same angle
I did a show some years ago - bits of furniture here, a departure from my main business which was period joinery, mainly sash windows and panel doors. Website totally out of date, keep meaning to revise it.
I can't follow that. Can you draw a diagram of what you mean? "Rounded" bevel. Do you mean "convex"?
The reason for wanting a flat bevel to the carving knife edge is the same reason that a flat bevel all the way to the edge is wanted in a carving chisel or gouge - the flat bevel acts as a jig in the same way as the flat back of a paring chisel acts as a jig - to keep the edge at a very shallow angle to the work to take very thin slices. Any rounding in the bevel, or a microbevel, prevents this. For the edge to bite with a convex bevel it must be pivoted all the way off the bevel, so paring cuts will be taking thicker slices because of the steeper presentation of the edge to the work.
Convex grinds won't stop you carving but they will limit the ability to pare and are generally harder to steer through a cut because of the variable bevel pressure as the bevel goes deeper into the cut.
Here's an explanation by Robin Wood:
https://www.robin-wood.co.uk/wood-c...he-best-knife-for-wood-carving-and-whittling/
Some nice pieces on your website, though. Can one charge that much for such things? Perhaps I should stop giving mine away. :)
But carve a nice spoon with yer knife and lets have some close ups.
Convex. A new tool is likely to be ground at 25º. I'd start it on the stone at 30º but dip as I go so that it ends up at 25º or less. Edge stays 30º the bevel curves away to less than 30º.
They are not particularly wanted on a chisel or a gouge
Like so much of modern sharpening it makes sense. That's why it gets such a following. But it's a delusion and much of modern sharpening is flawed and unnecessary so I'd guess this is too. Could be wrong!
Not many, but then I didn't want to make many!
Chap sells his spoons on our Saturday market. Seems to be popular I'll take a closer look
Might have a go. I did Robin Wood's bowl carving weekend some years ago. Still got the bowl somewhere.
You'd better inform Chris Pye and several other master carvers then - they've all been doing it wrong and should adopt the Jacob, er, "method".
Ah ha! Here is you problem You won't let "it makes sense" push out from your wetware the various strange hard&fasts concerning this and that. There's no virtue in refusing to change your mind no matter what evidence is presented to it.
Carve two identical spoons, one with scandi-grind carving knives and then one with knives sporting your convex grinds. Experience will tell you plainly, "You have been labouring under a delusion, Jacob. Whilst you're uninstalling this one, why not sweep away them others?" Experience is a wise woman, so she is. :)
I've just been out for a morning run. I was told my elbows stick out and my hands shouldn't swing across my chest. I'd never thought about it so googled - same comment and lots of good reasons given, from experts. Also lots of comment on how east African runners do it the "wrong" way even though they are world leaders! Well that's how I've been doing it! So perhaps doing it my own way is best, for me.
No harm in taking advice from more experienced people but a mistake to take it as gospel truth.
You seem to find others doing precisely that ridiculous.
O wad some Pow'r the giftie gie us
To see oursels as ithers see us!
It wad frae mony a blunder free us,
An' foolish notion:
What airs in dress an' gait wad lea'e us,
An' ev'n devotion!
Mind, I find myself avoiding various kinds of mirror in case I see something nastier than what can be seen in the woodshed. On the other hand, I have a "favourite" set of memories of very silly, embarrassing or just plain wrong things I've done in the past, which I force myself to recall regularly in the hope I don't do 'em again. Sometimes its works. Only sometimes. :)
