Sharpening Advice
Jarviser":1iiozjh3 said:
GEPPETTO":1iiozjh3 said:
Do you have any advice? Is it possible that I always have microscopic rust and on the edge it is seen by naked eye?
I had a similar problem with #44 blades which had sat in their damp cardboard holder and had pitted in several places deep into the steel, they were almost 'diseased'. I had to grind back at least 3mm to get to a sound piece of steel. Just a thought, if you have a wet grinder.
Hi Jarviser,
it seems me that the flat surface and bevel have a mirror finish and I don't see any pit of rust. However I'll try to ground backward and I'll try to hone again and to have the famous burr.
Thanks to have shared your experience.
Bug Bear posted his blade setting jig on Woodnet yesterday. Perhaps he will do so here as well. I think that we all have made these at one time or another. Here is the one I use with my belt sander jig (on waterstones I will use a LV Honing Guide Mk II). It enables precise and repeatable settings, but is also variable so that you can set any degree you wish. For a microbevel, just reduce the projection by 1 or 2 mm. This is not critical on a bevel down plane.
Regards from Perth
Derek
Wouldn't a regular combination square work just as well...you'd just need to be careful not to knock your edge against the stock of the square.
George
