wizer
- Joined
- 3 Mar 2005
- Messages
- 15,589
- Reaction score
- 1
I hope Paul doesn't mind, but he recently posted some info on sharpening a scraping plane blade and I think it deserves a thread in it's own right. Oh and also coz I wanted to ask a question
Paul Chapman Wrote
If you are getting dust, then the blade isn't sharpened properly. Here's how I do it. First I hone a razor-sharp edge at 45 degrees. The blade on my Veritas scraper plane fits OK in the Veritas Mk2 honing guide.
Get a piece of MDF and clamp a piece of wood on it so that the edge of the scraper blade is flush with the front of the MDF. Then using the burnisher dead flat go from side to side on the flat side of the blade (this work-hardens the metal)
Then turn over the blade, rest the burnisher on the bevel and run it along the bevel from side to side. Don't press too hard.
Then gradually tilt the burnisher to form the hook. You only need to take about 10 strokes at most to do this. What you should end up with is a hook that feels similar to the burr when you hone the blade.
Fit the blade in the plane and you should get long, silky-smooth shavings not dust
Hope this helps.
Cheers :wink:
Paul
Hope this helps.
Cheers :wink:
Paul
