Checked the motor shaft today and the shaft isint as small as I thought it was...
Defiantly not 15/16", so I am quite happy as I don't have to spend 50 odd quid on imperial bits
If the shaft proves to small in spots it will get a bead of weld ....
So I just drilled the sleeve out to 24mm and it was easy and quick...
I had to sharpen it beforehand and take a lot off the heel for there to be an acceptable relief angle.
The metal piece was not hardened or hot or neither was the bit
Guessing this bit was not used as often ..I can't remember
So I am baffled as to why this drill was so quick .
I still suspect the others have a worn taper in them ?
The only thing I can think of is I ground more relief on this one and didn't do it in one facet as it would have been wasteful.
,it was a mess before I started (angle wise)
I still think the relief on the other bits is more than enough though.
Now to make a jig that will score a line for the outside of the sleeve so I can grind and file to it.
This subject should be well discussed
I can't be the only one using large cheap bits with a regular pillar drill .
Thoughts ?
