Ttrees
Iroko loco!
Hello folks, I was intending to make some washers from this lawnmower blade.
I know the answer is likely two things that come to mind, heat treating it to anneal it, or
buying a carbide bit, but I'm wondering how I got this far using some cobalts up to 12mm,
and some various Silverline's/Lidl's to do the rest.
I've been watching all the engineering boyo's I could find about sharpening drill bits
and I haven't seen them discuss hard metals using HSS in detail.
From some old engineering pages on google, I see that the angle of the drill is less acute for harder steels, so have been aiming to replicate that.
As you can see a low grind compared to the grind for usual mild steel
Fair enough the edge does look gone on this bit below, but not the case for them all.
I have watched so many of the same videos, and tried finding one of the Lyle grinder
which demonstrated a grind which looked like it has positive sweeping on the end compared to the bit underneath.
Another question or something worth a remark, again couldn't find out the video where I watched it from... was a quick remark about the web pointing toward the cutting edge.
From that comment I get the idea that seems that I could be rubbing on the heel
I can't find a video nor article demonstrating freehand grinding for hard steels.
From one of the engineer folk on youtube, someone mentioned a turn needed for the big drills
This leads me to think is this the reason.
I must inspect the bits that I ground to do the job this far, and see if the chisel points are less flatter looking.
Not that I've used the chisel points as a lot of bits were used, but I have been grinding lower and lower for the last ones.
Has this affected geometry, and I need to twist the bit to counter the chisel from ending up like so...
and hopefully end up with a tip with more of an upwards angle, which might also be the key to not bottoming out on the heel?
Any comments welcome
Thanks for reading
Tom
Thanks for reading
Tom
