Simon_M
Paint finish on MDF is easy to get right and if a plywood edge is exposed there can be unpleasant voids to cover up on the cheap stuff.thetyreman":31pxrew4 said:'less effort'
Pete Maddex":3jh4ph9e said:Very nice!
A few lengths of 1/4 round will stop them slipping off.
Ryandotdee":1xfmyua2 said:Looks fantastic, I am envious of the joinery, wedged through tennons are on my list of joints to try, after seeing this project I think they have been bumped to the top!
AndyT":36o3dw1j said:Very nice! Proper woodwork, not just a diy job.
Trainee neophyte":354ommb1 said:Consider Phlebas, who was once handsome and tall as you.
...and rather good at woodwork, and self-deprecating, and a good egg generally. I really enjoy your posts; thank you.
Consider me inspired to work with hand tools (eventually, when I have time).
Simon_M":1h6yfcl3 said:It's a well executed project and the story leading up to it's construction provides "providence" (doubles it's worth no doubt too).
Was it necessary for the shelves to be pinned to the back to support the weight of filled jars?
I saw the plywood back and immediately thought that it was "out of character" with the shelves. However, you painted it and the "problem" is solved. Perhaps it would be easier to get as good a finish as you have - but with less effort, using MDF?
You have put the wall fixings beneath the top. That's good, and for shelves it's a good idea to not put the fixing on the top shelf. By putting it one shelf down (similar to what you have done) the fixing will hold the unit to the wall and the top will pull the bottom in - so no need for extra fixings etc.
The diagonal wedges remind me that a shelf doesn't always need a lip e.g. to hold a jar. Either you can omit the "lip" - does a jar move in the middle of the night so as to fall on the floor (no)? Or you might cut the shelf slots (and the shelf front) to be on a very slight gradient - to naturally hold jars etc. back against the wall, again without needing a lip.
Marineboy":1u0maff9 said:You’re probably embarrassed with all this praise Phlebas but it’s well deserved. Shows that you don’t need expensive hardwoods or indeed tools to make a well thought out, skilfully crafted and useful piece of furniture. Well done.
