mikefab
I've just bought an old Sedgwick MB planer thicknesser - what an amazing bit of kit compared to the recurrently faulty Jet which has been returned for a refund!
Anyway, I've been setting it up ready to get to work and wasn't sure about the correct height settings for the thicknesser infeed and outfeed rollers. I gave Sedgwick a ring and the man there spent a very helpful 10 minutes on the phone with me advising me about the roller heights and correct tensions for the springs, as well as a few other maintenance points. What a really impressive bit of customer service, given I haven't even bought anything from them and don't need any spares either.
In case anyone else is interested in this information:
Serrated infeed roller: 1mm below cutting circle
Outfeed roller: 2mm below cutting circle
The spring tensions should be different on each side of the machine, start with 65mm on the chain side, and 55mm on the non-drive side. This is apparently to compensate for the pressure exerted by the chain. He mentioned that these settings may vary with timber type.
I've yet to try these settings - waiting for the sparky to get a suitable supply in.
Thanks very much Sedgwick!!
