vin
Hello All, would any Sedgwick PT owners/users, have had this, or a similar problem, when trying to adjust the blades, on one side of the cutter block, the adjustment grub screw becomes partially covered by the bottom edge of the blade, making it difficult if not impossible to adjust, even using a ball ended key doesnt help, i cant access the hex slot, it happens on both sides of the block, and at the side nearest me, not on the fence side, the fence side adjustment is spot on, i think the chipbreaker isnt sitting uniformly in the slot, but the blades appear to be flush in the slot and sat correctly, so im a little puzzled.
Thanks in advance for any advice.
