I'm not sure Alie has a problem ?
Has he mentioned vibration ? or being led to believe its a MUST to secure lathe to floor ?
My bench isn't and i dont have any vibration issues, i however only turn balanced stock, ( or i have slow speed till tru ) and balanced shapes, like bowls\ boxes or spindle objects.
It would be a different case if i was hanging planks off the outboard ( if i had one ) like some of the wonderful wall hangings i have seen by members in here.
( or i had the motor and torque to do so ..... one day. 8) )
Maybe there are other facters at play for the assumed vibration, ? Dirty unseated tapers, untrue bed ?, the current bench is not true, or only has three legs on the ground like a bad pub table ?
Loose headstock, tailstock, belt, Worn out bearing ?
Alie, can you explain your want for securing, do you have vibration issues and have ruled out all other factors ?
Does your lathe wobble when off ? have a tug at it and its componants and let us know
Or are you indeed spinning planks of an outboard, or swiveled headstock ?
Best Regards
Loz
