Obviously it could, but practical, cost effective? I very much doubt it even in a production environment let alone a home/hobby workshop.nanscombe":by71psgg said:What do they make the likes of fibreglass pond liners and boats out of?
Could that sort of resin be used to coat the inside.
Maybe just make a fibreglass tube to go inside to hold the water.
Or better still a solid glass tube. An old jam jar, a drinking glass, a bottle, a test tube, etc.nanscombe":2a9027u5 said:What do they make the likes of fibreglass pond liners and boats out of?
No doubt it will work in the short term but I'm certain it would fail with time.CHJ":1pr0vq7u said:Well he certainly had confidence in it Doug, as you say personal tests with whatever species of wood you intend to use would be the sensible approach, note he said diluted, presume to get a deeper penetration of the product in the first instance.
I'm afraid I would not stick my neck out with such a claim for any item of mine entering the commercial market.
That amounts to making a fibreglass container within a wooden one. Simpler to drop in a ready-made glass one (or plastic , stainless steel, pot, etc) if you can find one to fit, or turn the vase to fit one.nicguthrie":1plq4wb3 said:I've a friend who's also a boating buff and very accomplished woodworker, he's always using, and recommending for use, West System Marine Epoxy.
It's a two part system that can be used with glass fibres for making custom fibreglass sheets, with filler granules as a filling compound, or as a paint fit totally waterproofing wood.
He uses it for repairs on his boat (he lived on it for years - it definitely doesn't leak!) And coats anything exposed to the water regularly with it. His rudder is ply and epoxy coating.
It'll make your turned goods waterproof, for sure, but it's not cheap, and like all epoxies it can be a pest to learn to work with, sticky, limited mixed usage time, etc.
For inner surfaces on large pots and vases, you could actually include a thin mat of fibreglass, moulded to the shape, to be certain that the expansion of the wood etc doesn't ever lead to weakening the epoxy.
All the best.
Nic.
Sent from my SM-N9005 using Tapatalk
I realize that Jacob, but I really don't think it'd be necessary to go that far, I just suggested the fiberglass as the "Ultimate Option".Jacob":2b6yk237 said:That amounts to making a fibreglass container within a wooden one. Simpler to drop in a ready-made glass one (or plastic , stainless steel, pot, etc) if you can find one to fit, or turn the vase to fit one.
