sealing plywwod
paulc
20 Aug 2003
Ireland
I have bought some waterproof plywood with which I'm making the foldaway walls of a market stall. I want to paint the plywood but wondered should I seal it first for maximum protection from the elements, and if so would a dilute pva solution do the trick? Cheers
I'd avoid PVA. The interior grade will not take exposure at all. Ehy not just give evertythin 2 to 3 coats of a good undercoat before painting, much as you would a front door?
Scrit
I recently bought some hardwood ply which I intend to paint. Whilst in the timber merchant I aksed their advice for maximum protection. They sugguested priming with aluminium paint, which I have done. It states on the tin that it is for priming hardwood and sealing softwood.
I'll let you know how good it is in about 10 years (I hope ) :)
Cheers,
John.
Cheers,
John.
Have you tried a couple of coats of polyester resin per side - I use that on my trailler - seems to last for years exposed to the worst of the elements and full of wet things all the time. costs £20 a gallon and I find that 7-800ml does one side. If you increase the amount of catalyst you can put on three coats a day.
mbk
I have not tried that but I can see how it would provide a good protection to the wood, provided that it did not crack or split.
In my case I am going to finish with white gloss paint, how well would that work with resin?
Cheers,
John.
