Carl P":2q3n72zb said:
I've just got lucky with some plane buying which means I have an excess of wooden bench planes. Maybe now is the time to make one into a dedicated scrub, I've looked into it and there seem to be two favoured sizes, roughly a No. 4 or a No.5, with an iron between 1 and 1 1/2" wide. Just wondered if anyone with some experience of them has any advice before I start.
Thanks,
Carl
I believe that you do not need length in a scrub plane. The main point is to get down past rough sawn surfaces to clean wood, PERHAPS doing a little flattening and easing out of humps along the way . It's possible you might even make a swale deeper. We're talking about an operation taking less than fifteen minutes time, if even that.
If you're starting with stock seriously over planned thickness (you will probably find yourself in this situation relatively rarely, or should at least) then you can certainly use a scrub to knock off the bulk. Otherwise you are just setting the stage for your much more moderately cambered foreplane to start the process of bringing a surface to truth.
