Mike-W
Hello all
With the chat on Scrub planes on the forum recently and having viewed Rob Crossman’s DVD ‘Rough to Ready’ I am thinking of initially flattening two Ash boards (for a chest top) prior to cleaning them up & thicknessing them on my PT.
Not owning a scrub plane I have thought about modifying my 45 year old Record #4 smother by grinding a 3” radius across the Iron, however as the Iron is only 3/32” thick I feel it will not be up to the job (too much chatter?)
I also have a Lie Nielsen Low angle smother #164 with a 3/16” blade. With the Iron ground at 25 degrees sitting on a 12-degree bed the cutting angle becomes 37 degrees, if I grind the Iron to 33 degrees this would return the combined cutting angle to 45 degrees, which I think is the normal cutting angle for a scrub plane.
If any of you have experience of using a scrub plane, can you suggest any reason why this will not work? Would a combined 45 degree angle be the best cutting angle for a scrub?
Mike
Mike
