Scroll saw table
flickr is happening.
SAM_1955 by gallowayphantom, on Flickr
they don't let you hotlink in the same way so you need to choose share on the flickr image and then the BBcode and size of image you want. hope that helps.
I've bought an old tea trolley on castors at an auction for a tenner. I thought this would be handy to screw the scroll saw down on to then it could be wheeled out of the way when not needed. It will probably need reinforcing in some way. Is it a good idea?, will it work?
I can't see a tea trolley working, especially if you are going to use one of the cheaper saws that vibrate a lot. The castors would be the problem as being not enough solid contact with the deck. However, I feel the way round this would be firstly to cover the top of the trolley with a thick piece of worktop and if you want to wheel it about get some wheels/castors from axminster, some of these fold out of the way when not in use and have brakes on them. After all that it should work with the scroll saw firmly bolted down and maybe some paving slabs on the middle shelf.
