aramco
last week my record power scroll saw was vibrating like no ones business, I got in touch with them they did reply with check blade tension , and take the side panel off and check the bottom bearing . Blade tension ok, side panel off nothing to see, so set the machine going at slow speed no problem,gently increased the speed till about 700 rpm that's when the vibrations started and got worse until till about the 1000 rpm mark then it stopped again smooth as silk - well maybe not quite -.
I informed record power and am not awaiting their input.
One thing I did discover was that despite having dust extraction working the amount of dust left inside was a lot so I may have to make a new side panel and put a connection in for the dust extraction and maybe plug the original one up for a while and see how it works .
I have asked is there a modification to put a quick tension lever on the machine aka hegner etc, last time I was in touch with them they said there might just be another scroll saw coming into their line up so asked about this ,I am awaiting their reply on all counts. will up date as and when that happens.
Have just been on a web site called " WISH " it is in wing wang land (china) I got a watch ,100 foot 16 mm para cord, 5 magnets 20 mm x 2 mm with a hole in the center 3 magnetic drill bit holders, and 50 drills bits and the total cost including postage and vat was £12- 95. There are 4 inch clamps on for £1 each, go an have a look and see if you can find any bargains.
john
Pain is the best attention getter
john
