Sounds like "tick sticking" for tilers. Very similarI am failing to understand the above. Sorry for being slow, can you explain this? Never heard of tiles being used before
Scribing a board with a pencil and an axe is (was) well known trad technique. I was taught how to do it and it was one of the main uses for a carpenters axe. I used it most often for scribing inside linings of sash windows during restoration work - they need to be a good fit for plastering.
It's a forgotten art @Jacob, 45-50 years ago every site joiner had an axe in their tool bass, usually a Stanley Steelmaster as I recall.
Skirtings, architraves, door/window linings, twist/propellor wedges for brick seams, hell we even used to take the bulk off external doors if they were overly too wide for the opening. If you knew how to use one correctly, it would be a pass or two with a No. 4 1/2 to perfect.
Yes I'd forgotten about chopping wedges! And lots of other trimming jobs. Axe still really useful but one thing which nobody would miss is the star chisel. I think I bought the last one from a local hardware shop and he wondered why I wanted it as everybody had hammer drills, before SDS drills which came along laterIt's a forgotten art @Jacob, 45-50 years ago every site joiner had an axe in their tool bass, usually a Stanley Steelmaster as I recall.
Not easiest any more, I think the jigsaw has superceded it. Here is advice for anyone wanting to use a jigsaw for an accurate result:The process is to 'offer up' the strip to the wall - scribe a pencil line running your finger along - cut the line - offer up again - cut the line again - as many times as it takes to get a fit to keep the old lady happy.
Easiest to rough most of it out with a carpenters axe until you get to fine details then a block plane etc.
Not very well I expect....
Most linings, infills, skirtings etc are MDF these days, not sure how well the old faithful axe would work on MDF
I like cardboard as well. I keep any stiffish cardboard and use it when I need to scribe any rough irregular edging/shapes. Just attach it with tape to what is gong to be the finished surface edge about 2 or 3" back from where the timber cut edge will be worked. It is easier to work with a knife or scissors and if I make a mistake just put another piece over it under the original and try again.It may be because I'm getting older but I find reducing the number of times I have to move heavy things into/out of position makes my body complain less the following morning
As a consequence, for anything that's heavy, bulky or awkward to move, I normally scribe & cut a large piece of stiff cardboard (sometimes with a batten attached to aid rigidity) to get the correct shape, then transfer that line to the 'real' surface, make an initial cut just inside that line to remove the bulk and then refine it from there.
Thanks for all the replies. The boss changed mind and now doesn’t want a scribed line. She still wants it “fitted” though. I think perhaps a face frame with the stiles straight lines against the jagged stone. Of course there’ll be gaps, but she’s now convinced that this will look better than a fully scribed fit. I tend to agree
Another option so you don't get out of the scribing that easily!
It depends on the colour of cabinet/stone etc but I have done similar and painted the infill matt black or a dark grey which creates a kind of shadow line so it looks freestanding but is still fitted so you don't have the problems of dirt and dust getting down the sides (this is why women like built in furniture).
My "joiners" axe here. Spear & Jackson. Weighs about 1.5 lbs. Not sure what the 1/4 stands for.More on wooden plugs/grounds here Axe cut wall plugs?
