Alternatively line your alcove; place boards against the side walls of your alcove, secured with plasterboard screws, line top & bottom with boards using angle brackets, and mount your shelves and clothes rail from there.
The top board and shelves will keep the side walls separate and the sides will support the weight.
I'd say 12mm ply would suffice? If it's a large alcove, use 18mm for strength?
Coat of water based paint for wood, will look gorgeous.
You may want to line the back to hide those horrible big holes....
