woodbloke
Pete's just been round tonite and asked me to have a look at a scratch stock he's just 'knocked up' :wink: from 6mm brass plate, a vast improvement on the one seen at West Dean a few weeks ago:
The first couple of shots show the front and back and this side shows the underside with the all important fence:
I used this on the dining table tonite with Pete just holding the wood...it's absolutely rock solid with no wobble at all, which is what normally happens with this sort of tool and so you don't all shout about evidence and shavings :roll: the final shot shows the bit of hard maple we were playing around with;
What is really impressive is that all the grooves you can see were made from one side. The tool even works on end grain...the groove is about 30mm from the end of the timber and no score marks were made prior to making the groove...again Pete was just holding the wood. I'm gobsmacked :shock: this is simply the best scratch stock I've ever seen or used...and I've used a few.
Pete will be along shortly to give you all the gory details - Rob
