No, I don't see the value in lifting an overturned burr with a point, but you can still use an awl to turn a regular burr on a tight inside radius.
D_W":csgt6viq said:It is a nice feature, and extends the time between burr reset, at least in large work (table tops, etc).
Bodgers":hfu3e63z said:Anyone had issues with the Axminster Rider No. 80 with having to regrind the bevel to 45 degrees? I read sir Paul was not impressed with it as it was set to 30...
I might look for a used 81 if the Rider isn't up to snuff.
Sent from my iPad using Tapatalk
thetyreman":3pqo08i5 said:Bodgers":3pqo08i5 said:Anyone had issues with the Axminster Rider No. 80 with having to regrind the bevel to 45 degrees? I read sir Paul was not impressed with it as it was set to 30...
I doubt the axminster one is any good you'll be wasting your time and money sorting it out, regrinding the blade should not be an option. I'd go with the veritas cabinet scraper, they aren't that much more than the vintage ones with what they go for now
D_W":1ex661qt said:Does anybody know someone who uses one on a regular basis for finishing? I think I've had four of them, and while it's interesting to learn to set them up, they're always more time and less good at the edges than a common stanley plane.
D_W":1svtoxfq said:Does anybody know someone who uses one on a regular basis for finishing?
David C":yzrutos7 said:In my experience, scraper planes are indispensable for cleaning up veneered surfaces.
This is the task that virtually nothing else will do satisfactorily.
David Charlesworth
patrickjchase":3g5v4k4u said:D_W":3g5v4k4u said:Does anybody know someone who uses one on a regular basis for finishing? I think I've had four of them, and while it's interesting to learn to set them up, they're always more time and less good at the edges than a common stanley plane.
By "one" are you referring to 80-style cabinet scrapers?
Like you I prefer planes whenever the desired cutting geometry is viable in both types of tool. For example, the picture I posted in the other thread showed a scraper configured with the chip-breaking face set back ~0.004" from the cutting edge. That's a fairly easy geometry to obtain from a separate iron + cap-iron in a smoothing plane, so IMO there's little point in using a scraper for that if you've learned to use a double iron. The scraper's iron is softer to start, and burnishing always carries some risk of edge damage, so the net of it is that the plane delivers cleaner results. I set the burr the way I did in that picture to make it easier to image and because it's an appropriate configuration for a "heavy" tool like the 112, not because it's something I use routinely.
I do use scrapers when I want to do very light work with a very small burr, but I use card scrapers for that rather than scraping planes or cabinet scrapers.
Or to be more frank, I think scraper planes and cabinet scrapers are mostly used these days to see if you can learn to roll a burr and then have a fun time with test pieces where you don't care about the edges.
