Clean up continued today.
Acetone and a wire brush eventually dissolved the resin and got the lower guides apart.
It helps to unbolt the two barrels from the carrier.
When you reassemble, the thumbscrew with a flattened end is used to clamp the rear guide as this may need adjusting more often. A capscrew with a coned tip is used to secure the mounting bar which has a V groove to match and prevent rotation.
The discs do indeed pull out of the plain bearings (probably oilite) once they're no longer gummed up with sawdust and resin.
When bolting the barrels back onto the frame, gently wind in the side guides until they touch and hold these square while you tighten up the capscrews. If you don't do this, it's possible for the guides to twist while you tighten up the bolts.
The band wheels after wire brush to remove the sawdust. Good condition. Tyres still sound. Need just a few minutes with some scotchbrite and metalguard to remove the fine rust from the machined surfaces.
Plated metalwork was cleaned with a brush, acetone as needed, and wiped over with metalguard for some extra protection. These parts are the fence, bracket and the support for the upped band wheel which is adjustable for tilt and height (tension).
