pe2dave
If you don't have the means to (accurately) measure side to side height differences, pm me. I have a pair of devices from my Scheppach 260 I no longer use.
Yes, start with one end a little high and tap the blade down until you get the blade ' kissing ' or just touching a batten on the outfeed table. Then insert the screwdriver under the blade at the opposite end and raise gently until you get the blade to just touch the batten. Rotate the block back and forth until you feel the blade just touching - machine plugged out of course. Tighten all the bolts until the block is ' nipped up '. It's a bit fiddly but once set set up it lasts until the next sharpening. I find this eliminates snipe completely even if it's not quite what the manual recommends.Thanks very much When you say to lift the blades with a screwdriver, how are you doing that exactly, are you using the small gap beneath the very end of the blades?
Thanks Dave.If you don't have the means to (accurately) measure side to side height differences, pm me. I have a pair of devices from my Scheppach 260 I no longer use.
Blimey, it's sounding more and more complicated. What have I let myself in for!Assuming you sort out any problems you have with the wedges, knife height adjusters and wedge locking bolts, no-one has yet mentioned that with planer/thicknessers settings start with ensuring all is set as it should be for thicknessing rather than for surface planing. This means getting the infeed and outfeed rollers, the chip breaker, pressure bar and anti-kickback fingers set correctly in relation to the cutter block and the projection of the knives. The starting point is setting the knife projection from the circumference of the cutter block correctly. Not all machines have all of the parts I've just mentioned. After getting that lot set up, which is normally a one-off task, or at least a very seldom undertaken task, the outfeed table of the surface planing part is set to the correct tangent line in relation to the projecting knives. Fitting replacement knives subsequently should be easily achieved through the stick dragging method others have described, or with use of magnetic type knife setting jigs.
I offer the above in case you find later, after you've got things set up as you think they should be working just from the outfeed surface planing table as others have described, you experience problems with the thicknessing function, e.g., severe snipe, poor feeding, and so on. If that's the case, it may be the thicknessing set up needs looking at. I'm not familiar with that particular machine, so if there are problems you might need to contact Scheppach for their specifications, e.g., the requisite knife projection from the cutter block. Hopefully the machine is basically as it should be and it will both plane and thickness successfully with no more than fitting new or sharpened knives. Slainte.
Thank you. I'm going to take another look at the wedges and screws and decide what to do from there. There's definitely 1 screw head that isn't visible, but I don't know for sure if the screw is just missing or if the head has been sheared off. I'll check the 2 screws that I 'think' may be stripped too.Yes, start with one end a little high and tap the blade down until you get the blade ' kissing ' or just touching a batten on the outfeed table. Then insert the screwdriver under the blade at the opposite end and raise gently until you get the blade to just touch the batten. Rotate the block back and forth until you feel the blade just touching - machine plugged out of course. Tighten all the bolts until the block is ' nipped up '. It's a bit fiddly but once set set up it lasts until the next sharpening. I find this eliminates snipe completely even if it's not quite what the manual recommends.
Hopefully nothing more complex than than getting the stripped threaded parts sorted or replaced, and then fitting new blades.Blimey, it's sounding more and more complicated. What have I let myself in for!
Yes, I have a sneaking suspicion that I might just be adding to this thread in the futureHopefully nothing more complex than than getting the stripped threaded parts sorted or replaced, and then fitting new blades.
I provided the additional information in case you found the machine's thicknessing settings had been messed up by the previous owner. Slainte.
Oddly enough I did begin to wonder how I'd get the wedge out if the bolts were stuck there, I was kind of hoping that if I could at least remove the blade then the wedge might have more wiggle room. I don't have a grinder but I do have one if those Dremmel clones and I think it might have a couple of very thin grinding discs with it, if I recall correctly they don't look up to much though.Is it possible that the screws you're calling 'stripped' are also sheared but still captive? Whichever, if you can't release the wedge, a precise bit of surgery on those screws might be necessary. I'm thinking in terms of a freehand grinder with a thin cutting disc, and it depends how confident you are about your aim. The priority would be to preserve the cutterblock at all costs. Safety goggles would be a must. That would be my method. A more tedious answer could be a fresh hacksaw blade. The wedge might be re-usable if you can excavate the screw remains and run a tap through to clean the internal threads, though it looks a bit chewed where the screw has broken & might be better renewed ...
I zoomed in on the photo of the broken bolt, it looks as though an attempt has been made to drill it out? Either way I'll have a go at getting that wedge out tomorrow.The wedge should come out, when all bolts backed off. Once out I would persevere in trying to get the broken bolt out. Heat up with blow torch, penetrating fluid or dill hole and use an easi out. I certainly would not tap to bigger size for the same reason as previously mentioned, balance.
Yes, I see that you're on the case ...!I was kind of hoping that if I could at least remove the blade then the wedge might have more wiggle room.
I've just spoken to Phil in the parts department and the bolts aren't listed as an item, no dimensions etc for them. He suggested that I just go and buy some hex bolts of the same size and use those. I asked if they needed to be high tensile and he just said that there doesn't appear to be anything special about them.If you contact NMA Tools, who are the main UK distributor for Scheppach, they will tell you if the replacement parts are available - [email protected]
They may also have a copy of the manual and various workshop guides on how to replace or recalibrate things.
For parts it will probably be Richard you deal with - I cannot speak highly enough of their customer service over many years.
For any parts like these on a fast spinny machine, I would ensure that everything was correct, standard and clean.
It's 40 Euros for a single v-clamp with the 5 screws included, at least the German website says 'Mit Schraube' which translates to With Screw. The blades aren't part of the kit. The v-clamp screws on the opposite side seem to be fine, they tighten as expected so I should only need the single kit.The joys of buying used! I personally would, from looking at the work involved and mess of bolt heads, bite the bullet and get the kit from the main dealer. Two or three knife block and is the price for all? The machined relief at the underside of head is there for a reason as too the square head. Buy some resin remover and clean the new ones after each use and bolt holes at change of blades. Get the right spanner if they sell that too.
