benrymnd
I have just cut some 6mm plywood patterns using a no2 blade and find that the plywood is splintering it isn't cheap plywood is there any way to avoid the splintering.
Regards Ray
Regards Ray
benrymnd":3eoxlfjo said:The splintering is always on the underside I have tried using masking tape on the underside as well as the top/pattern side but it doesn't eliminate it although the splintering is slightly less.
I will order somerevers tooth blades to see if it helps.
