Benchwayze
Ummm yes Tek you did. Oooops! :lol:
Grahamshed":1mss116c said:andersonec":1mss116c said:That sounds like a large channel to me, could you not widen it to get rid of the mistake, put in a filler strip then rout it again? no unsightly glue patches then :-k
Andy
The 'mistake' was a big one and a part of the channel which was 10mm from the edge of a 9 inch board ( 9 ft long ) is now only 1 or 2 mm from the edge...... But that does give me an idea, I could maybe slice that bit off and do it again, then biscuit a similar width bit to the back of the board...... or I could just chuck it away.
Benchwayze":2uau61vu said:Graham,
If you are considering slicing the channel off, and putting a strip on the other side, could you maybe fill in the groove you've done, and turn the board around, to groove the other side. The repair work might be hidden then? Saves ripping off and re jointing. Just a thought.
