colinc
Well, I used the demo saw a fair amount over the weekend. I was making four bookcases from mdf (to be painted) and cut most of the parts on saturday. I have to say that I regretted having to hand it back today so I shall most probably buy one.
It was very light yet powerful, it has a max cut of 40mm (probably 42 mm in practice) . Initially I thought I would buy its bigger brother but it was very light and controllable. 40mm is probably a good size of cut and is adequate for me. Also the flextrack just sits there with no hint of slip without clamping so it is very quick to set up.
I cut a lot of 18mm mdf using a used blade which it handled with ease. The flexiguide was easy to use and accurate, just limited in length but I didn't need to cut anything beyond its limits. The quality of the cut was good and at 90 degrees.
A big plus was dust extraction, I had to make up a 'special' (with duct tape) connector to join it to my shop vac (a cheap Earlex) but very little got away thereafter.
That's it really, it just did the job I want it for. and then all folded up into its little box - neat. I could spend time looking at Festool and spending more money but this seems a good value for money product suited to my needs.
Colin
Colin
