Yet another prospective purchase I'm considering. Can you buy these new anywhere or do you have to/are advised to go for an old second hand one? I've seen a few with the name Paramo come up on ebay every so often. In my naivety I avoided these as the name gave me a feeling of something dodgy but I've just done a search here and apparently the make's on a par with Record. So I take it these are worth bidding on - provided everything works. Aside from Record and Paramo what other decent old makes are out there?
Away from the issue of branding what other things should you look out for when buying one of these vices? All the ones I've come across seem to clamp unto a table top or bench but is this arrangement secure or can you get ones that can be screwed/bolted in place?
As for the jaws, what sort of length is best? The longer the better or do you ideally need one with short jaws for backsaws and another with longer jaws for panel saws, etc.? I've seen one saw vice with rubber lining the jaws and am wondering if this provides a superior hold than the more common unlined metal jaws?
Finally, the mechanism for closing the jaws, this usually seems to be a lever but is this good at applying pressure or would a screw type set up be preferable?
