Joe
Does anyone know were I might get a saw set designed for saws with 20 plus tpi?
Joel
Joel
Joe":zgs35yqj said:Does anyone know were I might get a saw set designed for saws with 20 plus tpi?
Joel
Joe":qdtjkseg said:Does anyone know were I might get a saw set designed for saws with 20 plus tpi?
Joel
Show off!!! :lol:I can't do these shortened urls! But I can, DaveL with my MOD hat on
Joe":24ibad7o said:Thanks for the feedback. I spoke to someone helpful at Tools for Working Wood who said that the 26tpi capacity of the fine saw set advertised on their web-site was a bit optimistic, possibly even a typo, but that they use them to set 18 tpi saws without any problem. Anyhow, I ordered one so I'll let you know how I get on. I realise that I might not need any set at all for cutting dovetails, but as I'm new to handsaw sharpening
David C":13iijgii said:A method which I believe was used, was an anvil plate with a slope towards one long edge.
Teeth were set with a small punch, the set being limited by the sloped surface.
David
bugbear":2yf7z0cj said:I'd practise on something easier than a superfine DT saw if I were you.
BugBear
Digit":1iabbljd said:If the punch is held at an angle to the teeth and the saw is held in the vice with the base of the teeth level with the angle iron support, the whole process is not too difficult at all.
Obviously, as in most things, practise makes things easier.
Roy.
In the vertical plane Joel with the hammer end higher, that tends to control the angle that the tooth is set over at.
The angle iron, or other support behind the tooth, needs a hard corner to it or there is a tendency for the tooth to try and bend below the base of the teeth.
I hope that makes sense.
I have been reading a lot on saw sharpening and pretty sure I read somewhere that filing the teeth, in the sharpening process, will generate "enough" set especially on a 26TPI?
So far I have worked on 16TPI but would dread to work on 26!!
