MikeG.
What are they actually called, and where can I buy some new ones? Or some old ones, for that matter.
If you're making it out of bog oak you owe me some off cuts or you're gonna have to change your signature mate. Just saying. I know you're gonna come back with some 'swap in swap out handle tool ratio numbers haven't changed nonsense' so let's be clear you are upscaling. That's the exact same as tool collecting. (*Gasps from the Jury*) Let's not pretend you haven't become obsessed. That's even worse than buying new tools when you have enough tools already and so do I.MikeG.":2j7mqlvz said:Thanks guys. I'm making a handle for a freebie hardpoint tenon saw I've had for probably 30 years, and the Phillips head machine screws screw straight into the plastic of the old handle. I think we can probably do a bit better than that.
AndyT":1tgviu6b said:Also available from the last UK volume saw maker, Flinn Garlick
https://www.flinn-garlick-saws.co.uk/ac ... ml#SID=432
Bm101":2v6kf04g said:If you're making it out of bog oak you owe me some off cuts or you're gonna have to change your signature mate. Just saying. I know you're gonna come back with some 'swap in swap out handle tool ratio numbers haven't changed nonsense' so let's be clear you are upscaling. That's the exact same as tool collecting. (*Gasps from the Jury*) Let's not pretend you haven't become obsessed. That's even worse than buying new tools when you have enough tools already and so do I.MikeG.":2v6kf04g said:Thanks guys. I'm making a handle for a freebie hardpoint tenon saw I've had for probably 30 years, and the Phillips head machine screws screw straight into the plastic of the old handle. I think we can probably do a bit better than that.
*Judge bangs Gavel repeatedly shouting 'Order! I will have ORDER!'
That's making your old tools pretty sweet lookin' for the sake of prettiness.
(*Jury faints in awe*)
*Mumbles into hand * Just leave the off cuts at the usual spot and no one gets hurt.
