- Joined
- 16 Nov 2021
- Messages
- 188
- Reaction score
- 58
Cracking Easter Savings
SAVE up to £125 on our PantouterRouter packages this Easter. Hurry for a limited period only!
FREE UK Delivery on all orders over £75
We ship worldwide, duty and tax included - click here to find out more
If you have any questions or need any help our team of technical experts are always on hand to give advice, email us at [email protected]
PantoRouter Ultimate Package
SAVE £125
SAVE £125
The ultimate setup with MAFELL spindle motor and full accessories kit
The PantoRouter is a precision copy milling machine able to cut a wide variety of wooden joints. The PantoRouter uses templates that allow you to accurately trace the tenons, dovetails, distances, drilling patterns or freehand contours. With the original templates, you can rout both Mortise and Tenons using the same template, increasing or decreasing the accuracy with minor adjustments to the settings. Copying pins with ball bearings in various diameters make it possible to adjust the size of a routing pattern again without changing the template. The PantoRouter table top can be tilted to enable cutting of a variety of joints including angles tenons, grooves or dowel holes into a mitred surface.
Includes
PantoRouter
MAFELL FM 1000 Spindle Motor with 8mm and 6mm Collets
V3 Template Holder
Auxiliary Fence and Fence Stops
Centre Scale Fence
Copying Pins Ø10mm, Ø15mm and Ø19mm
Centring Jig
Dust Collection Hood
Solid Tungsten Carbide Spiral Cutters 6mm, 8mm, 10mm and 12mm
Dovetail Cutter 8°
2 Hold Down Clamps (Colour may vary)
Templates: Mortise and Tenon, Variable Spaced Dovetail, Bow Tie, Diamond, Dowel, Segmented Mortise and Tenon, Slot Mortise and Box Joint
NOW £1,870.96
BUY NOW
