Sash window profiling and spindle moulders
Walfy
New member
15 Jun 2021
Oxford
Good evening all
I’m tasked with making a curved top window. Difference is that it doesn’t need to open so have come up with the below profile where the glass is held in from outside with the 1cm thick chamfered piece (to get a good paint adherence for weatherproofing) client wants to go double glazed which at this size is pretty thick.
My question is how to create this profile (in brown, drawing is to scale) - I have a router table table saw etc but am considering a spindle moulder.
Can this be done in a few passes on a spindle moulder? If it were straight the table saw would be fine but not for the top curve. And I suppose ultimately would it be safe to do?
(Forget the roundover/ and chamfer I can do this on the table)
Very grateful for the collective wisdom as want to be able to quote the job.
Thanks all
My first observations are: why the double rebate for the bead/glass, are you matching existing, and 10mm for a bead is a bit fleet, the least I go down to is 13mm, and have you thought about how to make the bead.
I agree with @deema a spindle is an ideal machine for this sort of work along with a ring fence accessory, but if your buying one, along with the tooling, to just do this job its going to get pricy.
Good evening all
Thanks all
Why not take piece in blue whatever you'd call it, right across the full width and take out the step (brown). An unusual detail.
Or make the rebate deeper so you could put a normal sort of glazing bead in it, and again get rid of the step.
Modern stuff not my scene but I'd guess it's not an uncommon problem and it would be a good idea to look at others' solutions.
Basic rule is don't re-invent the wheel, look at how others do it first.
Spindle moulder - yes by all means but there's a learning curve.
If your arc is a segment of a circle, then a router and trammel will work.
A router and template(s) would work also.
A spindle moulder is best for the job, though.
Thats one pass in a spindle with a ringfence or bearing.
For curved heads I make a sled from mdf with locating blocks for the workpiece and big over centre clamps to hold it flat safely.
Make the sled a good bit longer on the ends than required this is to provide a safe lead in and out, and also wider so your hands are well away from the spinny bits.
I cut close to the curve on the bandsaw to make it a lighter cut.
You could do it on a router table but it will not be fun.
I am assuming it is a curved head not a bowed window which is a bit different and more tricky.
I am also curious as the the reason you have the extra big blue bead. I do not think external beading is a good plan if you can help it. If you use low sightline heritage units you wont need such a deep rebate. Look at hodgesons heritage putty for DGU`s.
