gwr
How would you cut the pockets out when making a batch of sash n case windows? (hammer)
After all machining but before you glue and nail them together. Make sure you don't also glue and nail the pocket pieces themselves.gwr":353etp55 said:How would you cut the pockets out when making a batch of sash n case windows? (hammer)
AndyT":1qp17clj said:Plough the groove for the parting bead before assembly. Drill two shallow holes with a centre bit at the back, on the groove at top and bottom of the pocket, to give room to saw in across the grain, on the back, the toe of the saw going into the hole. Saw half the thickness of the wood.
On the front side, make the oblique saw cut at the top, working into the groove, half the depth, and the straight cut at the bottom. These cuts are about 3/8" away from the cuts you did at the back.
Rip down the groove with a keyhole saw from one hole to the other.
Knock the pocket hard with a hammer to split the short grain left between the cuts and free the pocket piece.
This all needs a diagram, but the point is that the pocket exactly fits the hole as it is cut from it. No waste and quick to do.
Eric The Viking":sa0ie0gg said:Following this with interest, but a bit confused. Did you mean this?:
I take Jacob's point about the oblique cut, but the other consideration is getting the thing apart to change the sash cords. If it's on top it is less likely to get gummed up with paint. but if it's on the bottom, it's a help getting the weights out... :duno:
AndyT":1nwgcpz9 said:If you stand in the room, and look at the board that makes the side of the box, the pocket piece will normally be from the edge nearest to you, up to the central groove. Consequently, the innermost beading cannot be nailed into the edge of it. So some books advise that it should be further forward, ie with the parting bead groove running down its centre. I've not seen that in the houses I have lived in and it would be harder to do - you would have to do a second long rip cut, and both rip cuts would be in the full thickness, whereas normally the parting bead groove takes away half the thickness for you.
