Guys,
A few times I have flattened my plane sole
on glass with sandpaper. I use some glue spray
to stick the paper on the glass.
I really hate the smell of the glue. I think it
is bad for the lungs. Also you need to clean
the glue after removing the sandpaper.
Using wet and dry sandpaper with water under
it to stick it works well, but the plane sole and
the frog start to rust almost immediately because
the water is touching those as well.
So I was thinking about drilling a lot of small holes
in the glass plate. Then putting some bag with
many small holes as well under the glass plate. Use
a small pump to draw away the air between the glass
plate and the sanding paper and this should make it
stick without making any mess whatsover.
If you want to remove the sanding paper, just pull
back some air and the vaccuum is gone and the paper
lets go.
Something like this:
Uploaded with ImageShack.us
What do you think guys?
Ali
lets go.
Ali
