craigjsmith
Morning Guys...
I have just made my first solid cherry wood chopping boards... And I am more than happy with the way they have turned out...
Only issue I have at the moment is that i routed out finger slots on either side and at each end there is burning.... HELP, how do i sand these out...... I tried for ages last night with sheets of sand paper and it simply takes far too long..... I also tried my dremel with small belt sanding discs but ended up with more as the rubber from the spindle made marks....
Am i missing a trick here.... Clearly i need to improve my routing to save the burn in the first place.... But how do i deal with these just now quickly and effectively...?
https://www.instagram.com/p/BLeNd2n...JI8w0/?taken-by=the_one_and_only_smiddy&hl=en
You can see the burn in the corner of the finger holes...
https://www.facebook.com/photo.php?...546.1073741829.100010937591711&type=3&theater
Thanks in advance for your help..
Craig
Craig
