andersonec
I have seen many mentions of sanding 'boards' or sand paper glued to something flat to sand your workpiece on, rubbing the work on the board rather than rubbing the work with the sandpaper. I am trying to make boxes and this technique would seem to give a better 'sharper' more accurate finish. I have a piece of granite I can use for the base but can only find the standard size sheets, obviously a larger sanding area would give more space to move the work over.
Does anyone know where larger size sheets (if there are such things) can be obtained and if so what would be the best type of paper/cloth, would it suffice to glue two sheets next to each other???
With thanks.
Andy
With thanks.
Andy
