Sanding Abrasive For Mini Belt & Disc Sander
Mikegtr
UKW Supporter
18 Jun 2020
Morpeth
I am wanting to buy quality sanding abrasive--different grits--for a mini belt & disc sander. Size of belt is 25mm x 760mm--size of disc is 125mm (5"). Can you recommend a good make of abrasive--where to buy? There are various makes of abrasive out there to choose from---from past experience of buying abrasive it pays to buy a quality make.
I want to buy a 5" loop adaptor kit to transform the 'glue on' sanding disc to the loop type. Where to buy?
Also- what make of sheet 'stick on' normal sanding sheets will last?
Your advice welcome. Many thanks
I'd like to know the answers to your questions as well.
In my previous searches, I came across a few places advertising 1x30" belts, but none sounded familiar.
If you want to try your luck, please report back on how it went.
3M Trizact
- https://bndabrasives.co.uk/product-...ng-belts/?_wcf_filter=true&width=325&_paged=1
- https://www.multitoolproducts.com/product-page/grind-belt-760-1x30-trizact-237aa
3M Cubitron II
https://bndabrasives.co.uk/product/...60mm-pack-of-12-various-grits-available-p120/
https://www.multitoolproducts.com/product-page/grind-belt-25x760mm-1x30-cubitron
This place seems to have a selection of various options, but again, I’m not sure if they actually deliver.
- https://prosharpeningsupply.com/collections/1x30-abrasive-belts
I haven't looked into swapping the disc for a hook-and-loop one because mine is permanently covered as I kept scraping my palm on the spinning disk while using the belt side.
