Sanding Abrasive For Mini Belt & Disc Sander
Mikegtr
18 Jun 2020
Morpeth
I am wanting to buy quality sanding abrasive--different grits--for a mini belt & disc sander. Size of belt is 25mm x 760mm--size of disc is 125mm (5"). Can you recommend a good make of abrasive--where to buy? There are various makes of abrasive out there to choose from---from past experience of buying abrasive it pays to buy a quality make.
I want to buy a 5" loop adaptor kit to transform the 'glue on' sanding disc to the loop type. Where to buy?
Also- what make of sheet 'stick on' normal sanding sheets will last?
Your advice welcome. Many thanks
