... I'll try to find time to take a few pictures that may help make things clearer. Slainte.
Well, just to try and tidy this up, I did get back to that workshop and took a few snaps. In truth I've come to the conclusion that this particular Festool router has some rather user unfriendly characteristics. Maybe it's just me, and others find this router to be the bee's knees, but I find this tool to be awkward to use. Having now used one, not mine I hasten to add, it know wouldn't be on my wish list. Hopefully the following images and a bit of text will explain.
So, below is how the Festool OF1010 sets up for routing grooves, rebates, mouldings, etc with a side fence. A user is 'forced' into this arrangement which will become clear later. What's good about it? Well, the dust port is angled off towards the back and away from the side fence in normal cutting, i.e., moving left to right and any hose tends to drag behind and mostly out of the way. What's wrong? The left hand most comfortably grips the handle which makes triggering and locking the trigger awkward; the run lock button is on the far side of the handle in this image. Easy triggering and locking is achievable by gripping the long handle with the right hand. Basically, whichever hand is used to grip the long handle user control of the tool is compromised, and I'd say safety is compromised as well.
Below can be seen the configuration of the side fence when the router is set up for use in the above image. Note the position of the cut-out.
I would be somewhat more comfortable, but not completely happy, using the router with a side fence set up as below. I moved the fence to the other side of the router base from the configuration above. Here I can grip the long handle right handed to trigger the motor with my index finger and lock it with my thumb. Plunging is controlled with the left hand turning the knob clockwise and anticlockwise to lock and unlock. In this configuration the dust port points forward and angled off the workpiece which means an attached hose is pushed less than optimally ahead of the router's left to right movement in a normal cutting operation, i.e., the opposite of a climb cut. In use with a side fence set up like this I found it encouraged standing face on to the edge of the material being worked which for me somehow doesn't feel natural. Normally when using a router with a side fence for operations such as edge profiling, rebating, etc, I stand side on to the edge being worked. This means I walk forward as I move along the edge, I can see what's going on, and it's comfortable.
The image below suggests that the set up in the above image isn't how Festool expect a user to operate the router with the side fence. As can be seen below with the fence mounted as it is the cut out is off centre and larger cutters frequently couldn't be used, particularly for work close to the wood's edge, because there's a good chance they'd hit metal.
I suspect that for many other hand-held operations, such as profiling with bearing guided bits, shaping using templates, and so on finding a comfortable method to hold the tool would be easy. Use with a side fence seems to be significantly compromised, whichever way the fence is fitted to the router base. In truth, looking at this router I'd be a great deal happier if the fence fitted 90º to the way it does, i.e., the fence rods passed from left to right as seen in the above image so that the fence was set at 90º to the long edges of the router base. That arrangement for side fence use would lead me to instinctively grab the long handle with my right hand and the plunge release/locking knob with my left and I'd use the tool in what feels like a natural manner. I can see that for Festool to set up the side fence configuration the way I'd like it would require a massive rethink in their router design department, and I'd guess very unlikely to happen.
I've tried not to be unreasonably critical and just described my experience with a particular model and make of router - it's possible other users of this model of router find entirely satisfactory, and it's just me who has some odd working practices, although I don't think that's the case. I have to admit though that if my small DeWalt router with its similar power output breaks irreparably, I'd almost certainly replace with another DeWalt and definitely not the Festool model discussed here. Slainte.
