Rorton
Ive been looking for a flat grooving blade for a while now to do finger joints and grooves in one pass on the table saw.
Current blade is a 254mm with 30mm hole, and I was looking at getting one of these CMT orange tool 150mm x 6mm x 30mm grooving blades.
Plan was to use direct on the bed of the table for grooves, and then on a sled to plough out material for wider grooves, lap joints etc, and also to use with a jig to make wider finger joints.
Am I Ok to use this blade for this purpose - I saw RagnBone brown on YouTube using one and there are quite cheep (£40) on amazon at the moment:
https://www.amazon.co.uk/dp/B00JBJH...olid=14PF4X7YKD4M6&psc=1&ref_=lv_ov_lig_dp_it
