YorkshireMartin":3c2fovv1 said:
tomasgursky":3c2fovv1 said:
Hello guys. I'm just wondering if any of you have a experience with Ryobi EMS254L mitre saw? I'm in market to replace Evolution Rage 3s I bouht last year as it is only good for cutting logs as you won't be able to cut anything square and same all the time?
I've come across that Ryobi one but can't find any decent reviews about how accurate it is and what's overal satisfaction with it?
Thank you,
Tomas
I fear you'd almost be replacing like with like if you took this route. And yes, the Evolution 3s is a pile of rubbish. I bought one too...regretted it at first use, but hey, it makes lovely fire wood.
So what would you suggest then? To be honest I had a look at one in Homebase and it didn't look that bad apart of that it was not fully assembled. I also spoke to Ryobi and raise my concern about a play in a housing and they said that should this be a case I've got rights to take it back. On the other hand it won't be used that much as I've got a sled for my table saw but I can't use it on full length of wood (2400mm) as I've got no space so need to cut it on mitre saw first. At the moment I will cut a full length roughly so I can use it in my table saw sled but then I ended up wasting a bit of wood.
This is my third evolution as previous two were even worse. By bad as I could get my money back but as I was working on project and didn't have any budget I just went for this one as on the Screwfix webpage says Trade rated. Maybe fire wood trade.
So I don't want to make the same mistake twice I just don't see a point to spend £500+ on something very decent that won't be used as much.
