Rod Cochran
It has been a few months since I bought the machine and in truth since I bought it I have not had the need for it much. It does exactlywhat it say on the tin as they say. The cuts are clean, the angle accurate and the movement smooth.
Fine adjustment of the angle is like alot of these machines its trial and error. Could do with some sortof fine adjustment screw so you do not keep going past the mark.
Best tell you what I do not think is good. The dust collection bag is very fiddly to attatch.The nozzle directs the dust at a right angle so it is right up against the side of the bag. Well it would if the thing actually directed any dust there at all! You need a vac.
The trenching adjustment is controlled by what they think is a selling feature. Its a cam with a single tightner. Unfortunately I have found this difficult to adjust and hard to keeptight.On one piece of work I found myself ploughing a deeper furrow than I wanted. I will change this for the normal thread and bolt arrangement.
Apart from that its a good machine with a decent stand for less than £400
