Rustins Plastic Coating reprised
Jake
5 Apr 2004
London
To set the context to this post, I got around to using this again at the weekend, refinishing my first ever substantial wood/DIY project - a pair of speakers which I built in my mid-20s around a Focal kit. They are built like a brick outhouse, but the oak veneer was glued on with contact adhesive and I think some (heavily, but unsuccessfully, discouraged) use of pledge type cleaner combined with the way the veneer was wrapped around curved edges had lead to some splitty-bubbles on the curves. Combined with the fact that these speakers are fantastically good fidelity and of big sentimental value, but also very unpopular in certain parts (often described as 'those coffins' etc) and a total renovation of our living rooms, they badly needed a refresh to avoid being cast out (me or them or both).
I have only used RPC once before, when I sprayed it to bare timber (with a stain on) without much prior thought or difficulty.
I agonised at length this time because by the time I decided to apply it (seeking the mirror gloss) I already had acrylate paint on them (Tikurilla Helmi). Rustins give dire warnings about using over other products. I have spent more time than I should have done poring over the various Rustins technical sheets and the advice on here, particularly in these threads:
rustins-plastic-coating-straight-from-the-horses-mouth-t61190.html
avoiding-brush-marks-in-rustins-plastic-coating-how-t94088.html
rustin-s-plastic-coating-rpc-t89048.html
As there is a lot of conflicting information and some more dire warnings about the trickiness and issues that can arise I thought it might help to post my conclusions and results.
1. I had no problem going over the acrylate paint as a base. It was well-cured (well past its 7 day full cure period).
2. But, I sanded through to the primer on a corner on my final prep sanding - damn. I got some titanium dioxide pigment (120gm I think) and got most of it to suspend into circa 0.75l of RPC. If I was doing this again with more pre-planning I would look for a white universal colourant (ie the same, but in a liquid suspension) as the powder was quite hard to get suspended with enough opacity and wanted to stay as lumpy gritty sludge. But I got there with endless mixing and straining through paint filter cones. The result did not have immense opacity or covering power, but I had a solid new colour-base after about four coats (but added some more for flatting-off-ability).
3. Most importantly, timing wise:
A. The instructions say that the recoat time is 2 hours and that this window closes when a critical phase is reached after a temperature dependent period some 12-24 hours. After that, re-application will result in the hardened skin of the previous coat not being properly chemically fused with the new coat, but instead melting and sagging as a visible film under the surface of the new coat.
B. The 'horses mouth' thread suggests that a minimum of 3-4 hours should be left before reapplication and suggests that the application window does not close for much longer than the official instructions suggest.
C. There are many concerning warnings on here about trying to apply too many coats too fast (but not in the official literature).
D. As I was doing the application in the (not quite yet in use) living rooms, I needed to get many coats on this weekend to get this done and dusted as it was holding up moving in which is not domestically popular especially given the reason for the delay is these very damn coffins etc. On the other hand, this did mean I could control temperature by overriding the CH to a hideously sweltering 22.5c for the whole weekend - a big advantage in avoiding potential pitfalls. But, also qualifies the potential universality of this experience.
E. In light of my time constraints, I decided to go with the official instructions in terms of application times and ignore all the countervailing warnings. So, broadly speaking, 2 hour recoat intervals. That is apart from at night, with a 8-10 hour break, knocking the temp down to 18c (Rustins minimum temperature guidance) overnight to avoid the risk of accelerating the end of the window by too high a temperature.
F. So, I applied 3 coats of the white pigmented RPC on Friday evening (8pm, 10pm, 12). All fine, no sign of any issues (but the white being fairly opaque for all I knew at the time this might be lending false confidence)
G. Although the instructions and 'horses mouth' thread suggest that each coat should be rubbed down with 600g wet and dry and then wire-wool to key for the next coat, I figured that really this was inconsistent with the concept of these coats being a chemical bond, and so a waste of film-building. So I did not rub down between these coats. I did then flatten back at c10am on Saturday (400g on the RO sander, low speed and fairly gently) before three more white coats at 10.30, 12.30 and 2.30pm, followed by another flatting back, and a last white coat (which had some pearl power added) at 4.30pm.
H. 7pm and 9.0pm on Saturday, two coats of clear with pearl went on, then a cover coat at midnight.
I. Another clear cover coat applied at c10am Sunday, then another flatting back (had to wait until the pearl was well covered) before the start of clear coating properly at midday, 2pm, 5pm. Flatted back, more coats at 8.30pm, 9.30pm and 11.30pm.
J Flatted back at 8.00am yesterday and another coat then and at lunchtime, 4pm, 6pm and 9pm.
No issues experienced (yet, touch wood) with bubbling undercoats, sagging films or intercoat adhesion. So (subject to temperature) I am not sure that the doubt which has been cast on the Rustins official instructions is deserved. The 2 hour interval seems to be enough, and the concerns about applying too many coats in a day do not seem like they are necessarily warranted (again, so far, and subject to temperatures). I got up to 9 coats on in a day (and I think I make that 22 coats in 72 hours) without any such issues (yet, touch wood).
4. Application was by roller. I tried a few on the early coats - posh microfibre velour types, short pile Purdy, but the best by far for this stuff were humble No Nonsense foam rollers - they loaded with the right amount of finish and applied and smoothed the finish off superbly. You do have to be quick. So for me on each face it was: Zip, zip, zip three vertical rolls, zip zip zip zip etc crossways to get the whole surface covered, then slower and gentler passes all around the border edges then laying off (lightest pressure, barely resting the roller on the surface) with 5 slow gentle vertical passes and then crossways the same. Time is now running short. Inspect closely for minor runs and orange peely bits and can usually get away with a bit more finessing. if you start to see little stringy-snowflakey bits this is not the roller disintegrating (my first passing thought) but the roller pulling the forming film skin off - STOP!. They do seem to redissolve.
Not much else to add but I will update after polishing them up this weekend. Hope this helps someone in future who is thinking about using it.
Aah thanks be to Gates, MS appear to have sorted out image sharing from OneDrive
Before
y3mCCIXMCwsNr0d8TpmXUaEyx-AQuTmUe9LW6qQ0ZGyVGLPhuUq1rayYLQPFAZB5VjVSH6E4RERutJJvMvZbHmZMH8xpGvv4Ja16YNeTCgxswB5GbdNjPDs14Vi1V_POdW8CqwRlG8zwHNhyDwkSMNuC2dJpc2ezgeC-DKRVjNzfT4
State of play now:
y3mFOdRMkJNmdTeA80M1phiUq7ewl14gSJOEsFDgMdj2pKNvcFq8E3ZMKQZra_cvEnHIs8vS3oxtGjtOZ0_mkTowvk44WpOCgCjUa3sPA0Ey0Y0FJ-76LMIuUuWLdQ0bbpTVW2mueyMkDJRlV9QlMaLdih-OsY8Atc4i9q5YtzZqUQ
y3mkaTbu5awTpeq2UGKF7eigffuWMh4RZWeyzAg0h2_FQgMwM6OqVIMF_4yRtTRb2nifYHKGiyNGdi0bll32DdtDYjzws_83WFymoJrLQjYkXepMtKTYV0MdEviGhs3d_tw4WvLOfpwyMsovrqlhEqhGu_81Rz9NknUQiKUzIYgbF4
y3mH_uh4LUdfmElUixlHOOj3rU_LT615firWnyiSctpIGrvbHRqxByks1M1sJyZXOQ1RinmdGM3D_c09kDEgaIsIS1pS1HNgULtDwA9zH33HtFIdmsBAp5Gp5OJH9HNt4ku0HhacsPobC0z9zHTbbVvVN7KvdC8l8P6WZeZ0Rk8ULM
Done (well,the painting/finish bit). Can anyone other than me see the pics? Gates is back in the kennel if not.
y3mmQUlb7v98TJBEMUx5jGYBeDzX5fitmysDm6jE_Q_MnboC59dHY5jiweELmRvTvqIvNcNfQSaFRZ73pYGZFbzlOD4AJ8uR4GHFY0TG8wckyFS_UwPhZWHiXBKlz7KuCkQMFMCziGimNzimychlYQHVAZgg0UCJHsVQK_LJPfIvTc
y3mKl3bu_OQuUYm6tEY5vmpGumsyyyRSeb6knJhW9k7bNfFOfxRSieYHEgxf1iQd8iHQdVyQkfwQ5VUO334XZt18XlAUIIuY2DO4JH2uB282Sb8QVUtSf-isLqz5tM640-wj6oV_vssdn7wnRj99Aet8qd53gnfFPdlsGyg5sBAFNQ
That's really impressive - I would have assumed it was done with expensive spray equipment, not ordinary rollers in a domestic setting.
Well done!
The before photo looks pretty bland- the finished pics look smashing ! It's given them a new lease of life- they look great. I'd be well pleased if I could get a finish that good.
Coley
Thanks chaps - Bill G will be grateful as I have let him out again for the night (Microsoft keep flocking up OneDrive by making it impossible to share photos easily and I got blanks on my work computer earlier so thought the problem was back).
Yes, they were looking their age... 20 years or so aagh where did that go. Looked pretty good new but time was not kind on the veneer. Also have some repairs to do on the foam driver surrounds (foam rings which allow the cone bit to move while keeping it constrained at the outer edge where it meets the metal basket frame) which have completely disintegrated - so not just my veneering which didn't meet the test of time.
Rollers yes, and lots of sandpaper... cure for everything. I have the spray equipment, but nowhere to do it at the moment. Ironically, the acrylate which became the undercoat was sprayed in those rooms when floor protection was down over the parquet, but the resulting finish was too boring to live with and then the spraying opportunity had been and gone.
For the record, sanding was 400g, 800g, 1200g, 1500g normal paper with a hard pad to keep things flat (but adding an interface pad for the curves), then 1500, 2000, 4000 foam backed pads all on the RO, then polishing using a Rotex in beast mode with 3 grades of polish.
Looking good. Rustin's used to sell P.C. in black and white - I don't know when they stopped. I always found the stuff good. I daresay if you sought perfection a clear finish over a white one is probably better, though.
Thanks Phil.
Yes, the white RPC would have been very handy indeed but in fact I would not have been able to get hold of it in time even if it was still sold. I sanded through the acrylate on a corner the evening before I had to start getting the RPC on - there is an art supplier within walking distance of my office so I could get the pigment at lunchtime next day.
In any case, I would have had to have clear-coated over the white as I wanted a pearl sparkle in the finish and that works much better in clear, and then needs lots more clearcoat over the top of it anyway as you can't sand or polish pearl.
So Coley asked for a link to this thread in the loudspeaker one, and I find all the photos died, here's replacements
y4mlkuiiC270Pg2ah9DnwxJ0SbrvGJ-kvH56PNKyTPT69Wu6HARytpQQureRPnRF7NXH9AntzMAuS9YUfbNegMg37Sq9L24MRzrZkddB6XkKMlu1scUCs41-9Z1QEw4vEkFMMuUV8y2u_MRE_aYfzp6WSthpkTtsO6wO5ZyR91vIlskcMrzuTVefnbol101awSzXAYP5PQwUAHRBYRucE0IIA
y4m2mnjH8pDsZT7K43iOab1_NT7TpobzpjVmCsOTd-OoJqvhAMGlrH2BTwud7Z7xt6_p8s2jgQZRtDfS9p0XMHeMOjoVGaHVAz3vZPqrUpkByOaJcS21V8uAegnqYSDOEZ_7PNkDEqTvXpD39aYOhM3uGPK6CvOHM4nPctPWpcaqkW3fuKiP1pNzQCiQoQfpQRzwtOqda1w_MrnIaWOXWIPlg
y4myMs80N85NUAEpBv6UTC8cZKKwjukaYv_Rtw9RBjp-4dfjbzCPPW3yNixjb99wGFsZ5O7qXnxJ_K3w6HijVjmbvFsqbRk4tMh3j_DPESZgG7pQ8UC11DaheqzAWvnPIHPTCeWyEdCZYjyMJZyROL9IB2VEVFG3xz-tz_VgjB4kKhVb_7vORRWGY1LBhpypYtsTmrsfHEAl1BKK-4yzvcS_Q
y4mv_OI1YKHQ2bsaLt_g88mEdQMO8i8UUM4i03uJAltihZPwNJEO_9FiBCt3B230qcywM2WNR_reO01EEIpUf1GAugudrqtsvHJ2ZskxN_uxFHi9Ojhil_n3lCtaTl_Ui64xpmBeFJnr9ki7IpxNWLDjBW1jsxZP71sYwCSBuWR_z_MSD4BaJCOpeOtkLUFU9-_tzjw7JWbFYoqe3TQilQa9A
y4m5FVJlm2SbjaoZ4PZeBYOXh8_ZEP882Yg5QMHNDz1izcKUGIWvpfpoQQPGUeQA82Rf1eoH2oK69Iy6f0QIcyfsrc5DhoaZnJNThPVVIeCzMsbK6ftsiUhxhaDZIHBFgdBDLqJuSbXskrbxmw6fiyqKOcAF0Iqxhi-LFFZmndL9jdK1FNm9AYM7pjfifTcipAsHZdxZH-x28mj7hVOkFr19w
y4me0wLwbnLMXeMLKk5V-ACZVtKvaAji5sadWIgcmnmziBKZcmkYfhEDB6iOd29_KWqxGAHeJeM6xeAPv4mmwq2I1fckwsrTP_btBjobqg0KnerwBGFdnPLORst9e0fWyttRdCTNxY691toLaHbPre2i9ym9bR7TaAvEZFXfz1CveDCXeyiH27TjDn6Y2z1kC0ccoRDaLVdBR5uN2hYQXkvlQ
y4mAz-9VGf-_d0IqwC1Dfy5RpWFA1R0YMk6uVYLKH6Jx8FaKk6tLwvd1Hv9aQxnqd4k-2n4IyKND0TVWM0QAUfibVZgD0hwkWeDss53ISqwDC5XXzb1M1wMIQWNfk4nO48inyW0rmks484FmqsytZ8M4L7t-MgKW6wx-I-V57zaVVacd8F7JcwuCqD5e5xyhEaSrtWl216INgnDmo-obkjrOQ
y4mBHMxBeSIWvWOcU_vB5V-uMp8sTQlM6jZ2hxkQWHZaELMSFkiOwv-A7PQCKr8IgCOM46eU-pJii38a0Tz3PxKLwbqTQctGvG8Lc7jzf2NvWdQI4IFzczaWGAdfZyrj9X0Wk1s0U-fs5_rC-_0-b-7L4bW-DO5Y41Ug5M-Zk1gEHkk1jtGayd3DB8Ux7zRG9Ca57ArCyMD1yauoKiY7qNLTQ
Really difficult to capture the pearl sparkle (mostly can't see it IRL either, just adds a little shimmer to the reflections and some 'pop' to the gloss) much more subtle than this makes it look
y4mF1PDYjFyZlNVPs4nhvCl9jy4MPlYG3S2lWhYkgnhPmREesk-HeY1K4O9bo1BJ__5KKNdUffYnVHJCpo9GD5z5L7jcugHnwncTOAvOqgUWHJKoFc2RqADSHOSo_k4oH4w-SteSk2iKB_J4KMmXxAK9AONyi_8nu5W6yObW14Zwk6l2LrZ5Qv1kkf50nnsaDKt5R-a_aubctT2EDWwYbk1UA
Sorry about the seemingly gratuitous green and blue in later pic, still doing bits and pieces (picture framing and hanging).
I shouldn't be slightly amazed by something I did myself, but I'd kind of semi-forgotten this was rollered, that seems nuts now I'm so used to them sitting there looking they've always been like that in their liquid gloss. Credit really goes to the joys of modern abrasives and sanders and maybe from me some slightly bonkers commitment to putting god knows how many coats on first (must have been this time last year almost exactly).
Thanks for redoing the pics ! It blows my mind the finish you achieved without spraying. I'm gonna make a note of the finish you used and stick it on my Christmas wish list.
Coley
I didn't know how it would turn out myself, and was - still am - a bit blown away. I thought it would end up reasonably okay, but hadn't really imagined getting to this level of mirror would really be feasible. None of it actually is anything very skilled - just picking the right stuff and then sticking the time in, over and over and over again. It felt pretty high stakes, but that was because I didn't actually know what I was doing, having never done it before, on some kit that means lots to me.
Anyway mission accomplished they are still here playing music and I don't get "god those coffins" these days, although if I mention that the absence of that I do get "huh, yes but now Elvis coffins".
I know this thread is 2 years out of date but I thought I might just add my ha'ppenyworth..
I have now used this on 4 or 5 different woodworking projects where I wanted (a) a hard-wearing, water and stain resistant surface and (b) proper shiny mirror-like finish
I don't have capability to spray, and I have had less success with the roller - mainly because a couple of the projects have been large tables 1500x700 and I just cannot finish it in time before it is starting to go off....
So, what to do. Well after this last weekend I can now say with confidence I can create a good mirror finish using anything - brush, roller, foam brush etc. I simply put 3 good coats on at 2 hour intervals - and did each 'face' in turn so that I was always painting the flat horizontal surface.
Then I left it in a warm room for at least 48 hours
Then i started at 400 grit on a dry sander to get it flat, then went through the grades of wet and dry - 1500, 2400, 3200, 3600 and 12000 before finishing with T cut by hand and a duster
There is definitely a learning curve but I am glad I did it and it might even become my go-to finish
Cheers all
Mark
