So, I've got a couple of Rolls Royce 24V starter motors from... something military.
They are very nice indeed and run very quiet.
But they take 24V and 200- 300 Amps when doing useful stuff.
I'd like to incorporate them into maybe a small home made milling machine or planer table or something.
What's put me off is finding a suitable power supply. I've thought of rewinding a MOT but... it's a bit Heath Robinson for something that's going to get regular use.
Then I saw this miniGB ZX7-200 220V 200A Mini Electric Welding Machine IGBT DC Inverter ARC MMA Stick Welder 220V
and I'm thinking... 20 - 28V at 200A ? Sounds interesting. I'm only looking for intermittent loads, maybe 5- 10 mins at a time.
But there's all that resistive / inductive load pineapples. Its like cross-ply and radials. If you get it wrong kittens will cry.
So in order to prevent crying kittens, can someone tell me if you can run DC motors from welding plant?
(BTW I've also looked at old oil tank MMA welding plant that you can buy for £5 but they're heavy AF, they smell, they sometimes leak, the voltage is wrong (7v?) & the same query applies to those too).
