wizer
- Joined
- 3 Mar 2005
- Messages
- 15,589
- Reaction score
- 1
yes having now thought about this I'd make a template, bandsaw to 1mm from line and then router with bearing bit. If it's Utile then it's the same family as the Balau that bit me, HARD. Take less than 1mm passes with the router. Really creep up on it or your student might not be as lucky as I was....
Tho as his teacher, you should really be telling him how to do it and if the router is causing problems then find another way. Such as bandsaw or jigsaw near to line and then good old sand paper with a flexible sanding pad.
